Design SuiteCreating detail viewports
Command
Path
Create Detail Viewport
View
Context menu
The Create Detail Viewport command creates a cropped sheet layer viewport that shows a detail view of any part of a drawing. A detail viewport can be created from a design layer, another sheet layer viewport, or a section viewport.
The viewport and its associated detail callout are linked, for easy navigation between layers. If the detail callout is moved or reshaped, the detail viewport updates accordingly. The detail callout marker can also be set to automatically update if the detail viewport is renumbered or moved to another layer.
To create a detail viewport:
Create either a detail callout (see Creating detail callouts) or a simple crop object (such as a circle or rectangle) on a design layer, on a sheet layer viewport, or inside a viewport annotation group.
Select the detail callout or crop object and then select the command.
Alternatively, right-click the detail callout and select the command from the context menu, or click Create Detail Viewport from the Object Info palette.
The Create Detail Viewport dialog box opens. Different options are available, depending on where the detail callout or crop object is located (design layer, viewport, or section viewport).
Parameter
Description
Name viewport as Dwg No./Sheet No.
Select this option to automatically set the Viewport Name to be a combination of the Drawing Number and the sheet layer name.
Deselect this option to enter a custom Viewport Name.
Viewport Name
If Name Viewport as Dwg No./Sheet No. is not selected, enter a descriptive name for the viewport. This name displays for the viewport on the Navigation palette and Organization dialog box. The name must be unique in the document.
Create on Layer
Select the sheet layer where the viewport will be created, or select New Sheet Layer to create a sheet layer. If there are no sheet layers present and a new one is not created now, you’ll be prompted to create a sheet layer after clicking OK.
Create drawing label
Creates a drawing label in the annotation space of the viewport
Use style/Use default settings
Specifies whether the label will use a style selected from the Resource Selector or the current preferences for the Drawing Label tool
Drawing Number
The next sequential drawing number available on the selected sheet layer defaults automatically. This number displays on the drawing label associated with this viewport, as well as on the detail callout. The number must be unique on this sheet layer.
Drawing Title
Specifies a descriptive title for the viewport, up to 63 characters. The title displays for annotation objects in the viewport.
Layers
Specifies which design layers are visible in the viewport
Classes
Specifies which classes are visible in the viewport
Scale
Specifies the viewport scale relative to the page; select a scale, or choose Custom and enter a Custom Scale value
Detail Level
Select the detail level for symbols and plug-in objects in the viewport; see Customizing detail levels for 2D and 3D components of symbol definitions and plug-in objects.
Wall, slab, and roof components display at settings Medium and High.
Display planar objects
Displays 2D planar objects for all viewport view settings; when deselected, 2D planar objects display only in Top/Plan view
Display extents beyond cut plane
Available if the detail viewport is being created from a section viewport; displays objects beyond the section cut plane
Display 2D components
Displays 2D components (when available) for symbols and plug-in objects positioned normal to the view; see Concept: 2D components for symbol definitions and plug-in objects. When the object has no 2D component for the view, the 3D component displays.
This applies only to viewports with hidden line rendering and set to a 3D view in orthogonal projection.
If the detail viewport is being created from a design layer section viewport with Display flattened deselected, the viewport displays 2D components only within the cut graphics.
Background Render
Available if the detail viewport is being created from a viewport; some modes enable the Background Render Settings button, to specify rendering parameters
Available if the detail viewport is being created from a viewport, and the selected Background Render mode requires parameters to be set. See the following:
Shaded settings: Shaded options
Custom Renderworks settings: Custom Renderworks options
Artistic Renderworks settings: Artistic Renderworks options
Hidden Line, Dashed Hidden Line, and Final Shaded Polygon settings: Line render options
Sketch settings: Applying sketch styles to viewports
Display 2D fills
If Background Render is set to Hidden Line or Dashed Hidden Line, displays 2D fills for planar objects and 2D components; see Fill attributes
RW Background
Available if the detail viewport is being created from a viewport and the Background Render mode is a Renderworks mode.
If a Renderworks style is selected, but no RW Background options are available, the background is controlled by the style; see Renderworks styles.
Detail Callout Settings
Specifies whether the detail callout marker will use a style selected from the Resource Selector or the current preferences for the Detail Callout tool
Auto-coordinate
Uses the Drawing Number, Drawing Title, and Sheet Number from the viewport in the detail callout’s marker, and updates automatically if the viewport is renumbered or moved to another layer. Deselect to enter this information manually.
Drawing Number/Drawing Title/Sheet Number
Identifies the viewport that the detail callout marker references. If Auto-coordinate is deselected, enter the information manually. Otherwise, the information from the linked viewport is used.
The specified sheet layer is activated, and the detail viewport is placed in the center of the sheet. If used, the original crop object is converted into a detail callout object.
You can create additional instances of the detail callout on other design layers or in the annotations of other viewports, if needed. See Detail callout instances.
To delete a detail viewport and its associated detail callouts, delete the viewport.
Viewport properties
Modifying viewports
Viewport status
Updating viewports
